It is currently Sun Jul 20, 2025 2:04 pm
 Post subject: #3
PostPosted: Fri Sep 30, 2011 4:28 pm
First name: Stuart
Last Name: Gort
My first tint....it went better than I expected.
I first sprayed maple panels with lacquer. I kept adding tint until I got the depth of color I wanted in one pass. Then I divided that by 6 and sprayed the guitar assuming I would have to build up six coats to get that depth of color. And it took six coats to do it......so that worked out well.
StuMusic
 Post subject: Re: #3
PostPosted: Fri Sep 30, 2011 4:37 pm
Online
Yummy!
PostPosted: Fri Sep 30, 2011 5:52 pm
City: Jacksonville
Man that's a good looking guitar. Some people just seem to be able to get a guitar to look just right.....
PostPosted: Fri Sep 30, 2011 6:19 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I don't know much about solid body guitars, but yours looks sweet. I will tell you honestly that the narrow part of the head stock up where the tuners for the two highest strings are located....that looks risky and fragile to me. However, if you or the potential new owner of this guitar handles it with respect and avoids knocks in that area, I see no reason why it couldn't last for many decades. I think you have built a very sweet and sexy guitar, and I find much to like about it! And this is only number 3? My hat is off to you!
Congratulations,
Patrick
PostPosted: Fri Sep 30, 2011 9:26 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Another great guitar, Stuart.
It looks like maple where the treble tuners are.
It would take more than a heavy knock to break taht, I mean that.
PostPosted: Fri Sep 30, 2011 10:46 pm
First name: Virgil
Last Name: Mandanici
State: FL
Awesome tint/finish - I am doing something similar with my laminate(s) on my current build, where people will see all 3 layers of wood from the front - this is a spectacular guitar - ESPECIALLY for number 3! Dang dude!
PostPosted: Fri Sep 30, 2011 10:49 pm
First name: Virgil
State: FL
Is that Sapele?
PostPosted: Sat Oct 01, 2011 12:15 am
Very fine lines Stuart, great work.
Wisdom is justified by her children
PostPosted: Sat Oct 01, 2011 9:06 am
First name: Stuart
Last Name: Gort
VirgilGuitar wrote:
Awesome tint/finish
Ya, thanks....it was encouraging to watch it build. Dividing the tint up into six coats was the trick to getting it evenly distributed. That was my main fear going into it. All that fear kind of evaporated after I had the second coat sprayed....it was already even at that point and didn't seem to be all that sensitive to spraying technique. Mind you, I had quite a bit of spraying experience prior to this...but none of it was on any surface as intricate as a guitar.
Yes....that's sapele on the body with a maple facing.
The neck is sapele, peruvian walnut, and maple down the center.
The guitar is 5.5 lbs.
StuMusic
PostPosted: Sat Oct 01, 2011 11:45 am
First name: Virgil
State: FL
I want to grow the gnads and attempt a finish myself on a future build - my hat is off to you for such a superb job with the tint. That Sapele has a nice weight to it - I used/have 2 more pieces of the African Mahogany for numbers 3 & 4 but need to buy some Sapele for #5 - love the ribbons in the grain - you have a great contrast with that tint on the maple against the sapele - I like how that makes the maple look - I'll be watching you!
PostPosted: Sat Oct 01, 2011 12:37 pm
First name: Drew
Last Name: Miles
City: Sarnia
State: On
Zip/Postal Code: P7C 3T3
gorgeous guitar man! very nice flow to the shape. are those p-90s?
PostPosted: Sat Oct 01, 2011 1:38 pm
First name: Hal
Wow, very nice! Those SD's will be great. What bridge are you using?
PostPosted: Sat Oct 01, 2011 1:50 pm
First name: Stuart
Last Name: Gort
The pickups are Seymour Duncan P-Rails (SHPR-2).
Here's a clip of me playing lead with this guitar over a basic acoustic blues track some guy posted at this web site. The clip covers a range of tones from clean to totally processed.
http://www.recordingproject.com/bbs/vie ... hp?t=40228
The bridge design is my own and they are made in-house from A360 brass alloy.
StuMusic
PostPosted: Sat Oct 01, 2011 11:34 pm
First name: Mark
Last Name: Sorrentino
Once again, props on the metal work. Your guitars are very clean. I like the blending of layers at the edge of the body, been wanting to do something like this myself, but with the sides being perfectly round.
PostPosted: Wed Oct 05, 2011 7:30 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I just don't know. idunno
That is awfully shiny.
Maybe a little 0000 steel wool would take car of that.
Seriously, that's beautiful from design to finish!
Is that Cat lacquer?
Kevin Looker
I'm not a luthier.
PostPosted: Wed Oct 05, 2011 11:54 am
First name: Stuart
Last Name: Gort
Kevin Looker
Thanks Kevin,
No, I tried cat lacquer but it just doesn't have the properties of good ol' classic instrument lacquer. I sanded it off and will probably not further entertain any thoughts of new fangled finishes. Talking with my Mohawk distributor, who does a LOT of furniture, he just boils it to...."there's nothing close to it in workability and latitude". I should have just listened to him in hindsight. I tried UV cure stuff, wipe on stuff, precat lac, catalyzed ployester...you name it. I ended up back with nitro. Basically, it's eaiser to achieve a high luster finish with nitro than with anything else I tried. Most of the last two years was spent fiddling about with finishing. This is after spending about two decades in business as a manfacturer, and developing finishing techniques for everything we made and sold.
I'll soon publish my entire finishing schedule using Mohawk products. It's a dependable and relatively fast way to get all the way downtown with regard to finishing. I've only just arrived there but once having arrived...it seems to be reasonably simple considering some of the ideas I was fiddling around with.
StuMusic
